Tired of the tattoos...
ruff
Ofer Kolton
I've had the Cobb hose for about a year. I don't put a zillion hours on it but by now it had about 400 hours. I run a Butler Max heat. First a 1 foot Good Year type hose whip coming from the machine and usually the first 50' after a Good Year too. After that and always in the home- I run the Cobb hoses.
So far it has been good. Definitely runs much cooler. Does not retain shape, but I always roll in fairly large loops while the hose is still warm. It never goes on a reel or live.
The see through cover of cobb's hoses is a little rougher (it has a little of a grab) but so far it held well.
Yes I would buy again.
But then I don't cook my hoses as some Canadians tend to do :winky:
That's why I always hand coil and hang my hoses.
ruff
Ofer Kolton
Ron. That's clearly not Canadian.
Maybe that's why you should move in with Damon in Redding CA.
He'd bitch about wanting to move away from CA and you about wanting to go back to CA of the north :winky:
Trip Moses
IMOL
Trip Moses
Neptune hoses hold up to my abuse. I like the look of the Cobb hose though.
ruff
Ofer Kolton
The issues with Neptune are:
  • Heavier.
  • Less heat retention and if running hot leaving a mark on the carpet.
  • Black death. (When the inner rubber detaches and gets into the solution.)
  • No warning when they fail, like the pinhole leaks in Parkers (not sure if Cobb's gives that warning.)
  • Slightly harder to unroll (more directional).
If those are not issues of concern then you're golden. Keep cooking.
Trip Moses
IMOL
Trip Moses
  • Heavier.
  • No warning when they fail, like the pinhole leaks in a Parkers (not sure if Cobb's gives that warning.)
Good info. My last hose was a Parker. It got kinks and it ruptured. I thought I’d try the Neptune. It never left any blue marks but it will leave trails if you leave it to long. I like the flexibility and it doesn’t get kinks. Maybe I’m taking better care. Maybe. Anyway got about 800 hours on this hose. I may go ahead and change it.
Ofer. I was 100% with you.....
UNTIL THE LAST PARAGRAPH.....
:madder::madder:
ruff
Ofer Kolton
Sorry Jeff. I must have been referring to Mardie :winky:
But he's before your time. Ask Willie.
Bob Savage
Bob Savage
I bought 100' for one truckmount, and 150' for the other. I am using a 220,000 BTU LP heater in each van.
Love it, but it does need 3 weeks of use to loosen it up so it is easy to reel up. Then it is pretty much kink free coming up on the reel.
Reactions: Trip Moses
I will buy it again. I plan on hand rolling after I do a post cool down after each job... it has a different ‘feel’ to it, yes, it’s cooler to the touch, yes, you get higher temps ATW....
I don’t know about longevity yet, only time will tell...
A job today, I cleaned a bunch of uph, mid way through, I presprayed the hall and bedrooms.... NO TATTOOS....
This carpet welted the last time I cleaned it, and I didn’t do the uph first... 1FDD5C39-E2E0-40A1-A093-89B33B6EA786.png
This carpet welted the last time I cleaned it, and I didn’t do the uph first...View attachment 90010
The types of carpets that commonly welt are polyester and olefin.
My last hose was a Parker. It got kinks and it ruptured. I like the flexibility and it doesn’t get kinks.
Kinks???
over 25 years using Parker Parflex 1035HT and never kink'd a hose :headscratch:
never had a rupture either
The jacket blistered and pin sprays develop, but never a side split rupture like I've had with Ineptune
