To all you freshwater rinse guys
amazingcleansc
What the hell? I tried straight H2O rinse with this Vortex 777 that doesn't have a chemical pump. Do you guys just agitate the hell out of your prespray or something? It seems like once all the prespray is gone the cleaning action is goes to nil. Do you guys walk around with a spray bottle and zap "tag along" spots?
I used the inferior heat lower flow old crappy '86 butler today WITH an emulsifying acid side rinse and there is a MARKED difference in how well it removes leftover spots. If you guys have been using H2O since the day you started, you may want to try something with emulsifiers on the back like End Zone. Unless I'm way off.
What do you guys do that I'm missing? This fresh rinse bullshit will drive me absolutely crazy if I do it every day.
Oh and the city water here is 6 grains.
dealtimeman
Everyday is Saturday.
Michael
you need heat and pressure to do freshy rinse and like i told you the other day i will use a rinse if i think it is needed on a job per job basis.
Art Kelley
I've been doing it for decades. You emulsfier rinse guys are the ones with the issues. When you shower do you run soap through your water. How does your hair feel? Just put down enough prespray so it is still wet when you rinse. A 260 degree Vortex fresh water rinse should be adequate.
DevilThomas
Yup...I agitate my pre-spray...sometimes with my Drimatic, sometimes with my OP machine...depending on conditions. Then extract with fresh water. No "spot" problems.
Use a good prespray, and agitate properly... and you could extract with a portable and get excellent results... :roll:
Get a 175 and use it... :wink:
dealtimeman
Michael
i agree with thomas about the 175 it is essential to cleaning a dirty carpet imo. i know other processes/machines can be used but for me, the 175 does it the easiest as operation comes naturally after using it for so many years.
also propper dwell time are crucial, as you need to let the juice work for you.
Art nailed it.........haven't bought rinse in I don't know when........
amazingcleansc
I think you are misunderstanding me, Art. I use End Zone, Ph of 6.5, not soap. But I will play your silly little game.
Shampoo is designed to rinse freely from your hair with water.
Rub prespray on your hands and try to rinse it off with water, you can even use your wand if you like.
After trying for a while you'll realize you cant get that slimy feeling off of your hands if you re-wet them (that's detergent residue), then spritz a little bit of something acidic on them. Voila! The slimy feeling is gone! That's because the detergent molecules are neutralized into WATER (wow) and a salt.
If you are using a quality chemical on the back (End Zone), the emulsifiers allow these molecules to rinse freely, much like your shampoo. It is a cleaner for your detergent.
With all due respect, you guys must either clean a lot of already clean carpet or either love to scrub the shit out of floors.
Peace
P.S. Michael and Jim, I love you guys. Don't stop answering the phone when my Vortex needs you.
floorguy
Doug
yup what he says...
and use a GOOD prespray
but i may try your analogy
Remember it also depends heavily on how soft your water is. Some peoples water is natrually pretty soft or in some peoples case they have a water softener on board or some people use RO Water. If you have a heavier water with lot of minerals or chems used to clean it up, then adding a rinse agent either alkaline or acid will help condition the water so it will do more work for you. When you look at how much chem you are actually adding to the rinse water, its really not that strong. Take End Zone, I think the dilution is 32 oz to a five gallon stock solution. I betch ya you could cut that dilution in half and still be very effective in rinsing.
Now the challenge with your vortex is either find a safe rinse agent that can be added directly to your freshwater tank that gives you the results you desire or add a chem metering system like Mikey added.
The Preacher
it looks like some guys have spent more time dumping waste tanks than you have time on the job.
something is amiss if you can't get a presprayed floor clean with a V. what flow are yore wands using???
amazingcleansc
2 jet turd wand. PMF ti wand comes today hopefully. The V is a work in progress also, My heat is around 190. still I could hold the turd wand over some dirt spots using H20 and get VERY minimal results. I dont think 50 degrees is going to change that.
The water around here is not hard at all, (around 5 grains i think?)
Nate The Great
What prespray you been using? What have you tried? Seems like user error to me. When you need an emulsifier for everything, you're really doing something wrong. Imho. :|
steve frasier
If you use a chemical rinse, you leave behind residue.
I use soap free depending on the situation. Sometimes 1 cup in a 7 gallon mix jug metered at 2 or less. Sometimes stronger. I also use a water softener.
Have you never seen Judsons O2 rinse demo/video
Why don't you try to scrub in the emulsifier and rinse it with soft water.
Carpet Cleaning Fool
Young Grasshopper...
The art of clearwater rinse is most difficult to master.
Only after walking barefoot cross bed of burning coal will you have the skills to master clearwater rinse.
Until then, wax on wax off young grasshopper...
SRI Cleaning
Anthony Firmani
I think the man thing is dwell time. So when you rinse, the soil is lossened. Sometimes I fresh rinse, somtimes I run liquid slurry.
amazingcleansc
Let me ask you this, would you fresh rinse a vacant rathole apartment?
ahhhhh....,,,,,
The force is strong with this one. yes...
The answers you seek revealed by question you ask..
Help you I will. "Yes".
Very good young grasshoper...
Aye Daniel Son! (bows very slowly!) And... 190 at the truckmount is no better than your butler.. and a 2 jet wand.. OMG like no way! :mrgreen: most these guys who are FWR.. are using higher flow
SRI Cleaning
Anthony Firmani
I have with good results (hose it down with prespray), but no I wouldnt by choice.
amazingcleansc
update... i was looked in my fresh tank today. it had more build up in it than I ever thought possible. When i agitated the sediment, it clouded up the water. I took a few hours and cleaned/descaled the shit out of it.
Something tells me this MAY POSSIBLY be the problem.
I have no idea how the poor tech at venturi lasted as long as he did without complaining that he couldnt clean shit with that water.
fresh or added rinse, either will clean if you've prepped properly.
AS for whether or not to use a rinse agent, do you not use a conditioner after washing your hair?
Art Kelley
Only homos use conditioner on their hair.
