Lets talk truckmount repair.
What brand/model do you own and what has gone wrong with it?
Not worn out but bad design issues or faulty parts
I'll go first.
Butler in a GMC 3500.
Premature cat pump failure.
2 chem pumps gone bad. Prone to failure Prochem design
Shaft seal on blower always coming loose. Weak design
Defective/leaky gas tank and bad fuel pump in GMC.
Vortex/UD1400
Pump clutch came loose and was damaged. Flawed design.
Low water shut off in fresh broke when baffle wall fell over
High Water shut off warps ever 2 years or so and fails
Baffle walls broke loose, leaky welds @ fresh tank. Weak suck design
Xentherm pump leaking oil prematurely.
Prochem chem pump failures (see Butler)
Lots of corrosion in Galvy parts in hose reels that should not have been used.
Upper Xen HX internal failure/leak. Premature
I'll go first.
Vortex/UD1400
