Truckmount overheating
Josh Almanza
Josh Almanza
Can my engine on my truckmount overheat if I have the windows to my driver and passenger seats rolled up? I have a air-cooled engine and I always have my side doors completely open as well as my rear doors also completely opened when operating my truckmount. It’s been raining a lot here in Houston lately and not to mention all the pollen in the air this time of year that’s causes me to have the windows closed.
Opening the front windows probably won't help much. If you think you need more airflow, consider installing a 12 volt fan to blow through your van
Reactions: Papa John
Just worried about it
I run my slide in with the side and back doors open. Up to 5 hours straight with no problems. If your temperature is really hot just consider a high volume fan to move more air through your van. Otherwise, you should be ok.
Reactions: Josh Almanza
