Water Float
I’m sure you could source the same one from a different source.. Is the juice worth the squeeze? $20 difference not worth the headache.. $50+ now I’ll find another source..
Try ask Smatty boy.. Anything that can happen, has happened to him.. :lol:
Do you see any place that sell the water box complete valve, float and rod?
I didn't even look since afaik it is just a valve......but I will
also the harwil level switch you don't necessarily have to buy the whole thing
you'll probably have to pull the switch part number after disassembly unless going straight to harwil (or supplier in vid)
Reactions: Living The Dream
Swani
All the parts for both floats had been taken off, so I'm starting from scratch.
I was able to get the complete waste tank float valve and assembly from Jon Don, but I had to order from Jon Don and Magic Wand to get all the correct parts for the water box. Now I'm shopping for a fuel tap kit. I just ordered something off Ebay. I hope it works.
