Water stain on carpet
Josh Almanza
Josh Almanza
What are you guys doing to remove water stains flooding from rainwater coming in and not get a call back?
U
Usually, replace the carpet. Rainwater, if it's backing up and flooding is not clean water.
Doug Cox
Doug Cox
After a carpet dries, usually water stains aren't a problem. Clean as usual, leave very dry, mist with fiber rinse, groom
How bad is the stain? Often it's just a dirt migration line which generally removes with normal cleaning. An actual browned area can be a little more difficult.
We use Prochem's Yellow RX, spray, agitate and clean as usual. It comes right out. If the stain was bad enough we may Post Pad it. Re-spray with Yellow RX and bonnet off. That usually takes care of it. :cool:
However I've seen some that when we come back a year, even two the is still a slight stain. Each time surprised that any of it is still visible.
So no absolutes.
