well is it the jud or is it the ss370
cu
the crew love the 370.they are running it at 400psi and a 4 jet 12"greenhorn the temp they are getting is 220 att without using the diverter which will get it up to 230 ( with the 5jet 14" and 600 psi we where getting 200att)
but 220 constent is fine for us
im running my jud at 600psi with a 5 jet 14" greenhorn wand and get 210 att
the jud gets up to full steam faster and the vac i feel is better
the ss is compact and quite and sounds like it,s running at 1/2 trottle when it's full open. it's a cool little machine with good heat
but for me to use it everyday would be like a v owner going to a cds ..he would be happy but...it,s just not a v
the SS370 will do it,s job and do it well ...but it's not a judson
at over 400hrs the judson is running fine we,ll see how the 370 is doing when it gets up there...i think it will be fine too...i hope so cause i cant fix it
if you get the filtter box make sure you get the NEW seal
Chris A
400 Hours ain't nothin, lets see how they both run with 4000 hours, then I'll be impressed.
Cu:
Have you ever noticed that few people respond to your posts?
Could it be that is because you type like Caesar?
Just asking. :roll:
