What blower is really needed for single wand cleaning at 100'-150'?
Job time is more important than dry time
because if you’re in a humid area of the country, it doesn’t matter what size your blower is, your dry time will be 4-8 hrs if the humidity is high
Meter Maid
The Undetective
But if I clean a room with both blowers and the dry times are about the same, and then I move onto the next room at the same time, then isn’t the job time the same? If the smaller blower is removing about the same amount of dirty water, laid down at the same psi, then how will the job time be different at 100’ of hose?
Andy
Doesn't Matter
Stop over thinking it and just clean the carpet. The little bit of time and moisture that you are talking about is minute. The dry time and the moisture left behind is attributed more to the tech than understanding every minute detail about the physics involved.
Meter Maid
The Undetective
I know, I just like the truth and like to know about stuff.
TConway
Thomas Conway
Most TMs can't hold 15hg with a wand on regular residential carpet, more like 9-12. Maybe on cgd carpet you can get that kinda lift.
That is why they can get away with a 20 hp motor running a 45 blower, and hp water pump cause most of the time the real load is only around 9 kg.
I know when I would clean cgd carpet with my legend it would do it but you could really hear the motor working very hard, my vac relief was cranked to 18hg. 90% of the time it never even came close to that.
Trip Moses
IMOL
Trip Moses
It’s as plain as day @Matt Wood ,cleaners like @FDA have no issues with just enough. They do not mind being limited by their equipment. They justify themselves by thinking guys like us are foolish to buy larger truckmounts. They don’t care about the truth they just want somebody to agree with them.
Meter Maid
The Undetective
It's never smart to assume someone's intent...
I have no problem with someone telling me bigger is better for my use... I just want to know why... with no Trump'esque rhetoric. When you have half of "experts" telling you there's no difference at 100' and the other half telling you there is... it forms more questions.
I'll spend money on bigger if it makes sense.
Foolish is you thinking I think you're foolish. I come here to hear from guys like you, so don't be all dickish about it.
Trip Moses
IMOL
Trip Moses
No equipment will fill the void of technique and experience.
But in the world of Truckmounts, less is not more. More is more.
Reactions: steve_64 and KSL
Trip Moses
IMOL
Trip Moses
To put it another way, eventually with experience a little truckmount is going to leave you unsatisfied with your work.
@FDA read your lift gauge, mine is as follows
full throttle no hose pulling 2" (2" lost)
full throttle 100ft hose pulling 5" (5" lost) *this might be wrong, its been awhile since I checked
full throttle 100ft hose & wand 6" (6" lost)
leaving me 10" of useable lift of my 16" (I've had mine set at 18" for 250ft runs but damn does it run hot)
water extraction, cgd and some rugs are only times I get my vac relief opening
the bigger blowers can't move more air down 2" hose but they can transfer their useable lift further
What type of runner is best? A sprinter or long distance? Depends on the race, but over 150ft I'd back the sprinter
Reactions: Meter Maid
Since you're considering spending over $20k on a bigger tm...have you thought about investing in a hotel room traveling to someone who has a 570 or everest and just working with them on a full day of jobs? Get the true feel of how the machine operates. You'll probably get paid for helping too, so that'll help pay for the trip. If you don't like what you've experienced, you've only spend $150+ instead of $25k+
TConway
Thomas Conway
Lift isn't really lost. Your trying to remove atmospheric pressure so it really isn't lost
Reactions: Hack Attack
I meant more lost from my total of 16" but like you said most wands or truckmounts can't generate more than 9-12" on the carpet (my eyes aren't good enough to check while wanding 🙂)
but theres a reason why guys use 2.5" and buy your wands
more airflow which allows that lift to be transferred to the carpet not "lost" in the system
Sierra Clean Care
I run a 47 @ 3450 RPM’s...
My Hg is set @ 17...
Do I have any regrets that I’m OVER DRIVING my blower, or taxing my unit?
No....
I run 2.5 for the first 50’ on most my jobs...
Let’s put it this way,
I WEAR EAR PLUGS FOR A REASON....
Sierra Clean Care
Better than it was before...
Yes, but still dirty.
Look at the waste water.
Is it dirty?
Do we all try to fool ourselves, and think that the moisture left is somehow clean?
NO, it’s never going to be 100% factory/new clean.
But we try hard to get it as close as possible...
it’s a balancing act.
I feel a big part of that is extracting as much as I can, as fast as I can....
TConway
Thomas Conway
Your target number IS 16 hg, if you were able to maintain 16hg at all times your vac hose airflow would be maxed out.....you would have the perfect system.
Reactions: DAT
Well Dan,
I use RO water...
I know I’m leaving the carpet cleaner than most....
Do you generate RO onboard or at home then fill?
My softener has been out of the van for awhile, I'm sure its not my imagination that the feral jobs don't seem to rinse so easy without it
DAT
Bill Cheryl
Is it dirty?
That must be why the steam action blower is water cooled and set to 20 hg...
Sierra Clean Care
I have a Light industrial system at my shop. It can produce 1880 gallons a day...
Of course I never need that much...
I carry anywhere from 125-175 gallons daily.
Yes, it makes a difference.
Would I ever go back to tap water.????
No.
Meter Maid
The Undetective
Damn good idea.
Reactions: Lee Stockwell
Meter Maid
The Undetective
Makes sense...
But at 100'-150' feet?
That's the thing... I know there are serious benefits with bigger blowers, but do those benefits really show up at 100'-150'? I've literally pulled 200' one time this year.
steve_64
Makes sense...
Because you know it's not a good idea. With my bane I would back up to bedroom windows to keep my hose run short.
Bigger machines will allow you to do bigger more difficult jobs that you may not have gone after. Buy what you can afford to invest in. The money won't be lost.
Meter Maid
The Undetective
You’re right. Definitely would never have to be concerned.
