What size tee jet for the Hydrofoce sprayer?
Good point, Brian reminds me....are we talking about ford or chevy....lots of guns out there, is it a genuine Hydro-Force or Uncle Sal's or one of the many clones?
Some room for variables here.
I know at 300-400 psi an 80 is fine, at 800 psi it's a bit wide, and a 65 will be your friend. Wet shoes suck.
Ron Lippold
why in the living hell are we still funking around with these hydro soakers get a boss sprayer or if your a girl get a multi sprayer. hardball protector bottles are perfect for the multi :shock:
KevinD
Kevin Dumas
Now, if you want to eliminate any draw problems put a 08 in them.
says the man with the 024 jetted wand..
08 is good, but something larger will only help you draw even better at high temps, and move faster.
ACE
My new HF has a quick connect down line of the chemical draw. I was thinking about adding 3’ of line and a small jet 6001 0r 60015 for pre spraying Upholstery. Do you think it would work with that small of jet?
jack zerkie
I have mine set up with quick release ends and use some from my exterior pressure cleaning 06 -08 and never a tip problem,also easy to find at Lowes and paint stores. jack z.
