- Apr 17, 2009
- Name
- Kenny Hayes
I thought he was clever!!You, of all people, shouldn’t try to be clever.
You know you could just toilet paper.My Rotary Extractor got rebuilt today..View attachment 111988
Well of course the f’n door was open, truffle sauce.Show us a picture of the open door
We use them on every job. Consistent performance, proper, multiple rinse flush without worrying about poor wand usage. Zero fatigue factor no matter the size of the job, higher heat on the carpet, and many other benefits to our clients and our technicians.The guy who use to clean whole homes with an upholstery tool come to mind
"Zero fatigue factor "...that's a stretch.We use them on every job. Consistent performance, proper, multiple rinse flush without worrying about poor wand usage. Zero fatigue factor no matter the size of the job, higher heat on the carpet, and many other benefits to our clients and our technicians.
cut back on the pain medse, it occurred to me that I’m usually far ahead of current trends and tend to be a harbinger of things to come,
I should have put that in purple textcut back on the pain meds
you’re delusional
The IICRC kill off all of the old guys or forget where they put the ancient manuals? All knowledge doesn't become false with every new generation or marketing push. Maybe just forgotten because fine denier high-pile carpet went out of style in the 2000s. so you don't see it everywhere anymore.You're a bit too stuck on this corn rowing thing. If you read the latest IICRC study they do not know what causes it. It's all speculation. As for CRB's causing it, I call bull crap. I cleaned thousands of homes using my CRB with soft brushes and have not had 1 issue. The times I have seen it happen, it was preexisting.
And 60% of those wouldn't see it or admit to seeing it, while farming their jobs.The IICRC kill off all of the old guys or forget where they put the ancient manuals? All knowledge doesn't become false with every new generation or marketing push. Maybe just forgotten because fine denier high-pile carpet went out of style in the 2000s. so you don't see it everywhere anymore.
Of course they know what causes cornrowing: agitation.
Could be from a door that makes contact, heavy objects moved across carpet or carpet cleaning tools - no matter which way they rotate or don't - if they aren't used correctly. A CRB will absolutely cause it if the wrong brush is used, run too long in one area, or run dry on particular types of non-commercial carpet.
If you don't see it from your own work, you know what you're doing.
Used the old rotary today. Hooked up to the lima bean special.
Please don’t make fun of my MartyWas that a dummy in the garage or is Marty visiting you?![]()
Jus gonna say the answer could be yes to both questions......Please don’t make fun of my Marty
I’ve been tempted to load up the rotary this week. I have the 360i and a Hoss, but I have been wanting to use a power wand ever since @Mikey P ‘s sexy pic.
If I were you I would use a filterIf I were you, I'd get a removable exhaust tip to angle the exhaust away from the home whenever you have to park that close to a garage. That was a little dangerous
That vacuum sucks!Used it today on a poly rug. First time in probably 2 months. Lots of PreVac first. Will still need post vacuuming before delivery. Rugs are a time suck.
