Would I miss the CFM?
Tony Wilson
Tony Wilson
been running a 408 prochem Everest for 11 years now. If I downsized to say a HydraMaster 423 or prochem legend GT would I miss the heat and vacuum?
I do 90% residential and my average hose run is 100 ft. My longest commercial run is 200 ft.
Tony Wilson
Tony Wilson
That’s what I was thinking. I’m a slow cleaner anyways so with the crazy heat my Everest generates I waste a lot of water. But I haven’t had an air cooled slide in for many years. How’s maintenance, oil leaks etc. on these new ones. My last air cooled was a legend SE almost 15 years ago. Belts and oil was the biggest issue. Always ran great though.
Askal
RIP
Al
Never had an air cooled that did not seen oil after about 1000 hours.
Stay away from air cooled slide-ins.
Unless they’re on an open trailer.
dealtimeman
Everyday is Saturday.
Michael
Yes you will notice the power difference, unless you move to the desert where water recovery isnt that big of a deal, as it will dry quick regardless.
This seems to be the latest trend into how to turn into a hack, part 1.
Tony Wilson
Tony Wilson
What trend ....Buying a smaller machine or moving to the desert to clean carpet? :biggrin:
Acp
Bjorn Marshall
everest is a 56 blower? what does the legend GT have?
You'll miss the everest on your big room residential and commercial jobs, plus the flow on your wand will probably be less to hold more heat so keep that in mind. So I don't think it's suction that you should be concerned about. I think you'll be allot slower because you're gonna want the heat of your everest and with a lower flow on your jets, it won't flush out the carpet as fast
I dont know about that..
The 370 performs hotter with higher flow, but I dont know how the GT or 423's HX work. Adapt your style to not sit on the trigger for so long.
dealtimeman
Michael
Are we are talking about getting from point a to point b or what?
Suzuki compact cars are nice, I think, and get you where you need to be most of the time.
steve_64
When you have to buy special tools to make up the difference yes you will probably miss the bigger blower.
Reactions: Living The Dream
You miss it. What you need to decide is do you need it.
Big heat big suck is not always needed. However if you clean restaurants, trashed rentals then you're going to needed to more from your cleaning pie. Agitation, Dwell time or stronger chems or maybe all. ???
