BestWayJay
- Apr 5, 2011
- Name
- Jason Lawrence
I never look forward to the this job. 500 square feet of a years worth of disgusting. Takes around two hours and we should really charge around $400 instead of $300 but after posting the video to FB I’ve already had 500 views and six friends request a cleaning so I hope that evens outGood job you earned your $49.95!
Oops that was meant to be your replyWhat was your psi/heat? What were you rinsing with/gph?
I used to think that as well but the 20 inch CRB has plenty of weight and with the stiff brushes on it I now prefer it over the Cimex for pre-conditioning. You can move much faster and even pick up a lot of dirt in the renovator trays while you’re at it.
My plan for my DISGUSTING restaurant, prespray, Cimex, 360i BH, edge with wand and/or edging tool while speed dry......get paid, and forget ALL about it, until the next one....
Sorry, that's what I meant......Shower feed it through the Cimex otherwise you can't spray enough product to work efficiently.
Last restaurant I did, used my CRB with the black brushes. It didn't even make a dent. I ended up pulling out my little Oreck and using the tile brush..... it chewed through it, but also left some damage. The owner was over the moon, me, not so much..... it was before I had a 175, or the Cimex.....Whittaker makes very STIFF yellow brushes for a CRB that work great on CGD and trashed poly.
the black brushes are for wool. not very effective on cgd.Last restaurant I did, used my CRB with the black brushes. It didn't even make a dent. I ended up pulling out my little Oreck and using the tile brush..... it chewed through it, but also left some damage. The owner was over the moon, me, not so much..... it was before I had a 175, or the Cimex.....
No, my machine is a Brushpro. White for wool, blue for resi, and black for CGD and tile.......the black brushes are for wool. not very effective on cgd.
They've got another, more aggressive one, I think it's brown, but I ain't ordering them, cause they are like 280-320$ a set.....No, my machine is a Brushpro. White for wool, blue for resi, and black for CGD and tile.......
You might want to read the instructions again. Mine is also a brush pro and white is standard, black is for wool. unless you have some other type of black brushes.No, my machine is a Brushpro. White for wool, blue for resi, and black for CGD and tile.......
Ron, I've got the 17"..... if I used the black on wool rugs, I'd be buying it...... the blue come standard with it, the white are for wool, and black are for CGD, and tile..... I was just looking @ the Interlink website....... I'm using them how Brushpro recommends......You might want to read the instructions again. Mine is also a brush pro and white is standard, black is for wool. unless you have some other type of black brushes.
maybe mine is an older machine. The black is definitely soft for wool and the white is stiff for everything else. Says brush pro on the machine.Ron, I've got the 17"..... if I used the black on wool rugs, I'd be buying it...... the blue come standard with it, the white are for wool, and black are for CGD, and tile..... I was just looking @ the Interlink website....... I'm using them how Brushpro recommends......
Strange. My machine is about 16-18 months old. It definitely has its place in my truck, but greasy, impacted CGD? Doesn't cut it for me. I've only done 3-4 jobs that I was disappointed in the CRB.... now that I've got other tools, I am really trying to tailor the tool to the job. 95% of the guys around me are one trick ponies....... either HWE, or VLM..... and both camps HATE each other.....maybe mine is an older machine. The black is definitely soft for wool and the white is stiff for everything else. Says brush pro on the machine.
you will be impressed with your new cimex.Strange. My machine is about 16-18 months old. It definitely has its place in my truck, but greasy, impacted CGD? Doesn't cut it for me. I've only done 3-4 jobs that I was disappointed in the CRB.... now that I've got other tools, I am really trying to tailor the tool to the job. 95% of the guys around me are one trick ponies....... either HWE, or VLM..... and both camps HATE each other.....
