SteamwayPro
- Apr 8, 2012
- Name
- George
I could easily sell it with a straight face. It does clean good. I wouldn't be cleaning nasty carpet either. If I ever move to another state I would only be cleaning one or two houses a day and I wouldn't bother with nasty carpet. That can be someone else's problem.Could you sell it with a straight face
in residential? I love it, and Damon
at the Enncapstore has specific chems for it, but I'm not sure I could.
That's how I'm doing it nowI could easily sell it with a straight face. It does clean good. I wouldn't be cleaning nasty carpet either. If I ever move to another state I would only be cleaning one or two houses a day and I wouldn't bother with nasty carpet. That can be someone else's problem.
Thank You !!!George you have a great system. You make VLM shine. Keep up the good work!
Over my dED body......!Thank You !!!
I believe VLM is the Future of Carpet Cleaning
Eventually there will be more businesses using the VLM Method for Residential and Commercial than HWE
2030 ??? 2035 ??? I don't know but it will eventually happen
LESS water MORE agitation !!!
There will eventually be more VLM Businesses than HWEOver my dED body......!
You don't use a trailer do you?Thank You I get very little respect here but I kinda like it that way
I like the challenge and I like being the outsider
Didn't you die once already Bawb?Over my dED body......!
Ya but I get anotherDidn't you die once already Bawb?
That's when the VLM slipped in.Ya but I get another
No only the once Kenny....I thought it was 8 times!
I'm disappointed! I thought you were like a cat!No only the once Kenny....
Stents......eleven !
Don't you hate those gates even though they're not hard to open most times, but the whole gizmos is a pita.The dealership called me back. I didnt bother trying to fix this in the kids play area.
The place is filthy.
Ya but I don lick mysefI'm disappointed! I thought you were like a cat!
after almost 40 years of VLM only, I'm retiring its been great my customers are begging me not to quit!! for certain use cotton pads, cleans better and much faster ,go slow, dont swing around let the machine and heat provided by going slow do the work. A good encap I use Certified shampoo bonnet cleaner, if pretty dirty i use a splash of double strength encap plus by masterblend, and pig out if those don't work. i use a kirby vacuum, you can pick one up cheap online. and the usual HP, etc. Yeah Mike I rarely do nasties, just a few apartments for property mangers, they were real happy, but hwe would be faster.
Yeah they are childproof.Don't you hate those gates even though they're not hard to open most times, but the whole gizmos is a pita.
You could buy a yarn store........Lifting 100 lbs machines even with a ramp or going upstairs in a home isn't always easy
I'm getting high jus looking at yor pattern......I could use a Carpet Brush/Rake to groom and it would be faster but on most carpet a CRB lifts fibers better and makes carpet look better than a Carpet Brush especially in the traffic lanes and in front of sofa
No I don't worry about making perfect groom lines. I just groom out the swirl marks and go to the next room
I vlm when I’m lazy and still young enough to tackle as much nasty carpet as I can.
After reading your comments I think your always highI'm getting high jus looking at yor pattern......
