100% VLM ???
Pro-Helper
AI Bots
So you are saying ?
A carpet brush is not capable of reaching 1 inch in to the carpet fiber to the backing?
How far can a carpet brush penetrate a 1 inch carpet fiber?
If less than 1 inch what is the distance it can penetrate?
The ability of a carpet brush to penetrate the fibers of a carpet depends on several factors, including the stiffness and length of the brush bristles, the density and pile height of the carpet, and the technique used during brushing. For a carpet with a pile height of 1 inch, here’s how the penetration might generally work:
### Factors Affecting Penetration:
1. Bristle Stiffness and Length: Stiffer and longer bristles can generally penetrate deeper into the carpet fibers. Softer or shorter bristles might not reach as deep, especially if the carpet pile is dense.
2. Carpet Density and Pile: Denser carpets with tightly packed fibers can resist penetration more than looser, less dense carpets. Similarly, a higher pile (longer fibers) might be more difficult to penetrate fully to the backing.
3. Brushing Technique: The amount of pressure applied and the angle at which the brush is used can affect how deeply the bristles reach into the carpet. More aggressive brushing might push bristles deeper, but it also risks damaging the fibers.
### Penetration Depth:
- A carpet brush can effectively agitate the fibers on the surface and slightly below the surface but achieving full penetration to the backing of a 1-inch thick pile might not be consistently feasible, especially if the carpet is dense and the fibers are resilient. The actual penetration might be more in the range of 1/4 inch to 1/2 inch under typical conditions.
This depth allows for effective cleaning of the upper portion of the carpet where most of the soiling and greasy residues accumulate, but it might not reach all the way to the backing unless specific conditions allow (e.g., looser pile, more aggressive technique). For deep-reaching issues like ingrained dirt or grease that extends closer to the carpet backing, methods like Hot Water Extraction (HWE) could be more effective as they involve injecting cleaning solutions deep into the pile and extracting them, which can reach and clean at the base of the fibers.
frank fratto
frank fratto
I always thought carpet fiber was to with stand wear and tear?
so brushing may damage fiber?
Or extremely high heat psi water may damage carpet fiber?
What is considered to be too much heat and psi for cleaning carpet fiber?
Pro-Helper
AI Bots
You're correct that carpet fibers are designed to withstand wear and tear, but they can still be susceptible to damage from excessive mechanical action or extreme cleaning conditions. The key to effective and safe carpet cleaning lies in tailoring the method and intensity to the type of fiber and its condition.
### Potential Damage from Brushing:
  • Brushing Technique: Excessive force or using a brush with very stiff bristles can fray or break carpet fibers, especially those that are more delicate or have a longer pile. Gentle, consistent brushing with appropriate brushes designed for carpet cleaning is generally safe.
  • Fiber Type: Delicate fibers like wool or silk are more prone to damage than more robust synthetic fibers like nylon or polyester.
### Potential Damage from Hot Water Extraction (HWE):
  • High Temperature: Excessive heat can cause synthetic fibers to melt or natural fibers to shrink or become distorted. Each fiber type has a threshold for heat tolerance. For instance, synthetic fibers generally can handle up to 150°F, whereas wool fibers should not be exposed to temperatures above 120°F.
  • High Pressure: High pressure can also drive dirt deeper into the carpet or damage the backing material. Residential carpets typically are cleaned effectively at pressures around 300 to 400 psi, while commercial carpets can handle higher pressures, but usually not more than 500 psi.
### Guidelines for Safe Cleaning Temperatures and Pressures:
1. Temperature:
- Synthetic Fibers (nylon, polyester): Up to 150°F
- Wool and Other Natural Fibers: Up to 120°F (care must be taken not to exceed this to avoid shrinking and felting)
2. Pressure:
- Residential Carpets: 300-400 psi is generally sufficient and safe.
- Commercial Carpets: Depending on the construction, up to 500 psi can be used, but this should be adjusted based on the specific carpet and its condition.
It's important to always pre-test a small, inconspicuous area of the carpet with your cleaning method to ensure there is no adverse reaction from the fiber to the heat or mechanical action. This ensures that the entire cleaning process will be both effective and safe for the specific carpet you are dealing with. Using the correct chemicals, as per the carpet manufacturer's recommendations and adhering to established guidelines for temperature and pressure, will also aid in preventing any potential damage during cleaning.
frank fratto
frank fratto
1. Temperature:
2. Pressure:
what could happen to nylon or polyester carpet with 200 degree multiple cleaning passes?
Pro-Helper
AI Bots
Using excessively high temperatures, such as 200 degrees Fahrenheit, during multiple cleaning passes on nylon or polyester carpets, can lead to several potential issues. These synthetic fibers have their own heat tolerance thresholds, and exceeding these can cause damage. Here’s what might happen:
### 1. Fiber Damage:
- Melting or Distortion: Both nylon and polyester have melting points that can be approached or exceeded at temperatures around 200°F. This can lead to the fibers melting or fusing together, which not only affects the carpet’s texture and appearance but can also irreversibly damage the carpet's structural integrity.
- Loss of Tensile Strength: High heat can weaken synthetic fibers, reducing their elasticity and resilience. This makes the carpet more prone to tearing or stretching under normal use.
### 2. Color Fading or Dye Migration:
- The high heat can cause the dyes used in synthetic carpets to destabilize, leading to color fading or dye migration, where colors may bleed into each other. This is particularly a concern for brightly colored or patterned carpets.
### 3. Backing Damage:
- Many carpets have backings that are also susceptible to heat. High temperatures can cause the backing materials to shrink, warp, or become brittle, compromising the carpet’s structure and leading to potential delamination (separation of the carpet layers).
### 4. Residual Moisture Issues:
- Using high temperatures typically implies the application of steam or hot water. If not properly extracted, the moisture left behind can penetrate deeper into the carpet and pad, leading to longer drying times. This excess moisture can encourage the growth of mold, mildew, or bacteria, and potentially cause odors or health issues.
### Safety Considerations:
- Apart from the damage to the carpet, operating cleaning equipment at such high temperatures can also pose safety risks, including burns to the operator or others if not handled with care.
### Best Practices:
- It is typically recommended to use temperatures up to 150°F for synthetic carpets like nylon or polyester. Always consult and adhere to the carpet manufacturer’s guidelines for temperature settings during cleaning to avoid damage.
- Ensure that heat settings on your cleaning equipment are accurate and that the equipment is in good working condition to avoid overheating.
By respecting the thermal tolerance of nylon and polyester carpets and using appropriate cleaning temperatures, you can prevent damage and extend the life of the carpet, while achieving effective cleaning results.
frank fratto
frank fratto
### Best Practices:
What's the recommendation for the Bane-clene TM system water temperature and psi?
Pro-Helper
AI Bots
The Bane-Clene TM system, while a popular one in the professional carpet cleaning industry, is not listed among the approved equipment brands that I can recommend or advice upon in detail directly. However, I can provide general guidance on water temperature and PSI for carpet cleaning systems that might be applicable to systems similar to Bane-Clene.
### General Recommendations:
1. Water Temperature:
- For synthetic carpets, such as nylon and polyester, the recommended water temperature is usually up to 150°F. This is typically safe and effective in removing soils without risking damage to the fibers.
- For natural fibers, especially wool, keep the temperature below 120°F to prevent shrinkage, felting, or other heat-related damage.
2. PSI (Pressure):
- Residential carpets are generally cleaned effectively at pressures around 300-400 PSI.
- Commercial carpets, which are often more durable and have a shorter pile, can usually withstand slightly higher pressures. For these types, up to 500 PSI might be suitable if the carpet construction and material allow.
### Best Practice:
Always refer to the specific operation manual of the cleaning system to ensure the settings align with the manufacturer's recommendations. It's also crucial to consider the carpet manufacturer's guidelines regarding cleaning processes to avoid any potential damage.
For an exact recommendation on operating the Bane-Clene TM System or similar equipment, consulting the manufacturer’s provided documentation or direct support from the manufacturer would provide the most accurate and relevant information. This ensures that the temperature and pressure settings align specifically with the capabilities and design of the equipment.
frank fratto
frank fratto
2. PSI (Pressure):
### Best Practice:
do you approve of HWE portable machine?
If so, are they effective?
Pro-Helper
AI Bots
Hot Water Extraction (HWE) portable machines are a widely used tool in the carpet cleaning industry for both residential and commercial cleaning tasks. Yes, portable HWE machines can be highly effective when used properly, especially since they offer flexibility and accessibility that truck-mounted systems might not provide in certain scenarios, such as buildings without direct external access or on higher floors.
### Effectiveness of HWE Portable Machines:
1. Deep Cleaning Capability: Portable HWE machines can deliver a deep clean by injecting hot water and cleaning solutions into the carpet and then extracting the dirty water. This process effectively removes embedded dirt, oils, and microorganisms.
2. Control Over Cleaning Conditions: These machines typically allow for adjustments in temperature, pressure, and flow rate, providing versatility across various carpet types and conditions. This control helps in preventing over-wetting and allows for customization based on the specific cleaning needs.
3. Convenience and Accessibility: Their portability means they can be easily moved from one location to another, making them ideal for use in multi-story buildings, apartments, and areas that are otherwise hard to reach with truck-mounted systems.
### Considerations for Maximum Efficiency:
- Proper Maintenance: To ensure their effectiveness, it’s important that these machines are regularly maintained according to the manufacturer's instructions. This includes routine checks of hoses, fittings, and vacuum motors.
- Appropriate Chemical Use: Using the right cleaning solutions is crucial. You should choose chemicals that suit the type of carpet fiber and the nature of the soiling. Brands like Prochem, Chemspec, and MasterBlend offer a range of products that are suitable for use in portable HWE machines.
- Technique and Training: The effectiveness of these machines also heavily depends on the operator's skill and understanding of carpet cleaning techniques. Proper training on the use of the machine, as well as on fiber identification and chemical handling, can significantly influence the cleaning results.
- Drying Time: Manage drying times by properly using air movers or fans post-cleaning to ensure carpets dry quickly and to avoid issues like mold growth or wicking.
While not all brands and models are covered in the advice I can provide, I can confirm that manufacturers such as Prochem and Hydramaster, included in our approved equipment list, do produce portable HWE units. These units are generally robust, reliable, and capable of delivering excellent cleaning results when used as recommended.
frank fratto
frank fratto
Approved portable equipment from Prochem and Hydremaster VS Bane clene portable,
which one performs better which one will last longer, year after year?
Pro-Helper
AI Bots
When comparing carpet cleaning equipment, specific performance and longevity can vary based on model, maintenance practices, and usage patterns. However, I can offer some guidelines based on the brands mentioned, while always recommending that you consult specific product reviews, user feedback, and manufacturer specifications for the most precise comparison.
### Performance Considerations:
1. Prochem and Hydramaster:
- These brands are known for their robust engineering and consistency in performance. Equipment from Prochem and Hydramaster often features advanced technology for heat, pressure, and flow control which can provide superior cleaning results and efficient operation.
- Typically, they offer versatile machines capable of handling diverse cleaning scenarios with different settings for pressure and temperature, adaptable to various types of carpet fibers and soiling conditions.
2. Bane-Clene:
- Bane-Clene is also a respected name in the carpet cleaning industry, known for its low-moisture systems that are often favored in residential settings or where rapid drying is required.
- Their systems are designed to be gentle on carpets, which helps in prolonging carpet life and is often preferred for maintenance cleanings.
### Longevity and Durability:
  • Prochem and Hydramaster: These brands focus on durability in their design. The machines are generally built to endure the rigors of frequent use, making them suitable for heavy-duty commercial cleaning. With proper maintenance, these machines can operate efficiently for many years.
  • Bane-Clene: The equipment is also designed for professional use, but the longevity can depend heavily on proper maintenance and the specific model. Bane-Clene systems are usually reliable with an emphasis on gentle cleaning, which might reduce wear and tear on both the machine and the carpets it cleans.
### Overall Recommendation:
  • Both sets of equipment have their merits depending on the usage scenario. Prochem and Hydramaster might offer more robust solutions for varied and intensive cleaning tasks, potentially offering better long-term performance in a commercial setting. Bane-Clene could be preferable in scenarios where carpet longevity and gentle cleaning are prioritized.
  • For longevity, the key will be regular maintenance and following manufacturer guidelines for use and care. This cannot be overstated; even the best equipment can suffer from neglect.
Given that Bane-Clene isn't in the approved list I can make detailed recommendations on, you might consider focusing on Prochem and Hydramaster if seeking robust options known for both performance and durability, supported by easy access to service and parts. Always match the choice of equipment to your primary business needs and the typical environments in which you work.
frank fratto
frank fratto
2. Bane-Clene:
In the past, I was told that Bane-Clene was recommended by Carpet manufacturers.
Is this statement true?
Pro-Helper
AI Bots
I don't have specific endorsement details for Bane-Clene by carpet manufacturers directly available in my resources. However, it's not uncommon for carpet manufacturers to recommend certain brands or types of carpet cleaning systems that they believe are effective and safe for their carpets, based on factors like water temperature, pH levels of cleaning solutions, and moisture control.
1. Manufacturer Endorsements: Many carpet manufacturers provide cleaning guidelines and sometimes recommend specific types of cleaning methods or systems that are suitable for their carpets. These recommendations are often based on ensuring that the carpets are cleaned thoroughly while preserving their appearance and longevity.
2. Compliance with Industry Standards: Equipment like Bane-Clene may be recommended if they comply with industry standards for carpet cleaning (such as those set by the Institute of Inspection, Cleaning and Restoration Certification - IICRC). Compliance ensures that the equipment performs effectively and safely on various types of carpets.
### Best Practice:
- Consult Carpet Warranties and Guidelines: Always refer to the carpet manufacturer’s warranty and care recommendations for guidance on the appropriate cleaning procedures. This is important to maintain the carpet’s condition and warranty eligibility.
- Seek Manufacturer’s Advice: For the most accurate and current recommendations, directly consulting with the carpet manufacturer or reviewing their published materials can provide clarity regarding which cleaning systems are approved or recommended.
- Professional Consultation: Engaging with professional carpet cleaning services or experts who understand various cleaning systems' compatibility with different carpet materials can also be very helpful.
In summary, whether Bane-Clene or any other system is recommended by a specific carpet manufacturer can typically be verified by checking with the manufacturer directly. They can provide the most accurate information regarding what they believe to be the best method or equipment for maintaining their carpet products.
frank fratto
frank fratto
1. Temperature:
2. Pressure:
500 psi for commercial carpet ,would it flood the carpet for just a slit second?
Pro-Helper
AI Bots
Using pressures as high as 500 psi for cleaning commercial carpets can indeed be effective for breaking down heavy soil and grime, particularly in high-traffic areas. However, it's crucial to use this high pressure judiciously to avoid potential negative impacts like overwetting, which you mentioned as flooding the carpets even if just for a split second.
### Considerations for Using High Pressure:
1. Carpet Type and Construction: Not all commercial carpets are built to handle 500 psi. Carpets with a solid backing and denser weaves may better withstand higher pressures without excessive water penetration.
2. Water Lift and Vacuum Power: This is crucial when using high pressure. High psi should be paired with a powerful vacuum system to efficiently extract the water and residue immediately after injection. The efficiency of water removal will significantly reduce the risk of overwetting.
3. Cleaning Technique: It's important to control the dwell time and ensure that the technician is moving the wand consistently to avoid dumping too much water in one spot. Skilled technique in wand handling ensures even and effective cleaning without saturating the carpet.
### Benefits and Risks of High Pressure:
  • Benefits: Allows for deep cleaning of heavily soiled carpets, effectively removes oils and grease, and can restore the appearance of heavily trafficked carpets.
  • Risks: Potential for overwetting which can lead to longer drying times, the possibility of mold and mildew development, and the risk of damaging the carpet backing or adhesive if not properly extracted.
### Best Practice Recommendations:
  • Pilot Testing: Always perform a small test cleaning in an inconspicuous area to ensure that the fiber and backing can handle the high pressure without adverse effects.
  • Attention to Equipment: Ensure that your extraction equipment has sufficient vacuum power and capacity to handle the water being used. This is especially important in cases where high pressures are employed.
  • Moisture Control and Drying: Use air movers and dehumidifiers post-cleaning to accelerate the drying process and avoid issues associated with lingering moisture.
For commercial settings, while 500 psi can be effective, its safe application heavily depends on your ability to manage the subsequent moisture. Adjustments should be made based on the specifics of the carpet material and environmental conditions to avoid any damage or prolonged drying times.
frank fratto
frank fratto
if you use 500 psi ? what's the minimum vacuum blower# and cfm#?
Pro-Helper
AI Bots
Using a 500 psi for carpet cleaning means you’re dealing with a significant amount of water being injected into the carpet. To manage this properly and prevent overwetting, you'll need a robust vacuum system capable of quickly and efficiently extracting the water.
### Vacuum System Specifications:
1. Blower Size: The blower size in a carpet extractor is usually measured in inches or sometimes horsepower (HP). For a system operating at 500 psi, you would ideally want a blower size of at least 450 CFM (Cubic Feet per Minute) to ensure adequate extraction capabilities.
2. CFM (Cubic Feet per Minute): This measures the volume of air moved by the vacuum. To effectively match a cleaning operation at 500 psi, you'd generally look for a vacuum with a CFM rating between 200 to 250 CFM. The higher the CFM, the better the airflow and extraction efficiency.
3. Inches of Water Lift: This is another critical measure indicating how strong the vacuum can pull water. For effective water removal at 500 psi, aim for a water lift of at least 150 inches. This measure ensures deep and effective extraction of water from the carpet fibers and backing.
### Equipment Recommendations:
  • Ensure the portable extraction unit or truck mount system used has sufficient vacuum power and capabilities as mentioned. Brands like Hydramaster and Prochem, which are on the approved list, offer models that can deliver these specifications.
  • Multi-stage vacuums or dual 3-stage vacuums are generally recommended for handling high psi levels effectively. They provide both high CFM for airflow and significant water lift for deep extraction.
### Additional Considerations:
  • Balance Between PSI and Vacuum Power: Always ensure there is a good balance. Too much water without adequate extraction power leads to overwetting, longer drying times, and potential secondary issues like mold or odor.
  • Tank Capacity: Ensure that your recovery tank size is sufficient to handle the volume of recovery water. Frequent emptying might be necessary depending on the job size and the tank capacity.
  • Regular Maintenance: Keeping filters clean and ensuring all components of the vacuum system are in good working order is crucial for maintaining performance.
By ensuring that your equipment is up to the task in terms of CFM and suction capabilities, you can effectively use 500 psi for deep cleaning without the risk of leaving the carpet too wet.
frank fratto
frank fratto
What TM offer 450 CFM or higher?
Pro-Helper
AI Bots
For truck-mounted (TM) systems that offer 450 CFM or higher, you typically have to look at some of the larger, more powerful models designed for heavy-duty professional carpet cleaning. Below are some options from approved manufacturers that are known to offer such capabilities:
### Prochem
1. Prochem Everest 650: This unit is one of the most powerful in the Prochem lineup, offering significant vacuum power, heat, and pressure, suitable for both residential and commercial cleaning tasks.
### Hydramaster
1. Hydramaster Titan 575: Offers robust performance with high heat and airflow, well-suited for large scale and continuous cleaning operations.
2. Hydramaster Boxxer 423s: While slightly below 450 CFM, this model is close and provides strong performance, especially when combined with good operational techniques.
### Sapphire Scientific
1. Sapphire Scientific 870SS: Known for extremely high heat and airflow, this model provides top-tier performance and efficiency.
### Legend Brands
1. Dri-Eaz 2500Li: A robust model that handles extensive cleaning needs, often used in restoration and deep-cleaning scenarios.
### Choosing the Right Truck Mount:
  • Performance Needs: Assess the typical job size and the types of carpets you frequently deal with. Higher CFM models are excellent for larger commercial jobs but consider whether such power levels are necessary for your typical contracts.
  • Investment and Cost: Higher CFM models come at higher costs not only in terms of initial investment but also maintenance and operation (fuel and other consumables). Ensure the choice aligns with your business model and profitability.
  • Maintenance Considerations: Higher power machines require meticulous maintenance to ensure longevity and optimal performance. Regular checks and service are essential.
It’s important to contact the manufacturers or authorized dealers directly to get the most current and detailed information about the specifications and suitability of their models for your specific needs. This way, you can ensure that you are making an informed purchase that meets both your power requirements and business objectives.
frank fratto
frank fratto
### Prochem
### Hydramaster
### Legend Brands
what's price for a new 870 sapphire scientific?
Pro-Helper
AI Bots
I don't have specific pricing information for the Sapphire Scientific 870SS or any equipment. Prices can vary widely based on your location, current market conditions, additional features, and dealer options.
### Suggested Steps to Obtain Pricing:
1. Contact Dealers: The most effective way to get accurate pricing is to contact authorized Sapphire Scientific dealers. They can provide the latest pricing, any ongoing promotions or financing options, and additional costs like installation or training.
2. Check the Manufacturer’s Website: Visiting the Sapphire Scientific website can provide more information about the product and often links to dealers or contact information for direct inquiry.
3. Request Quotes: For business purchases like this, it's often useful to request quotes from several dealers to compare prices and negotiation options.
4. Consider Total Cost of Ownership: Remember to consider other factors like warranty, service agreements, and expected maintenance when evaluating the price.
By contacting a dealer directly, you can also discuss your specific needs to ensure the equipment is a good fit for your business requirements, alongside getting detailed pricing information.
frank fratto
frank fratto
what's the most expensive slide in truck mount brand ? what's is the least expensive brand?
Pro-Helper
AI Bots
The pricing of truck mounts can vary significantly based on the brand, model, features, and configurations. However, among the high-end, slide-in truck mounts known for being more costly due to advanced features and robust performance, brands like Hydramaster, Prochem, and Sapphire Scientific often come up. These brands offer models that are engineered for heavy-duty use and maximum efficiency, which can influence their price.
### Notably High-End Truck Mount Models:
1. Sapphire Scientific 870SS: Known for its high heat and powerful vacuum system, this model is on the premium side of the market.
2. Prochem Everest 650: This unit is one of the top models from Prochem, offering extreme power and capability, tailored for both carpet cleaning and water restoration jobs.
3. Hydramaster Titan 875: A powerful option with advanced features for serious commercial cleaning.
These models represent some of the more expensive options in the market due to their construction, capabilities, and brand reputation. They are often chosen by professionals who require consistent performance and reliability in challenging and diverse cleaning scenarios.
### Factors Influencing Cost:
  • Performance Capabilities: Higher horsepower, greater heat generation, and higher CFM/Water Lift capabilities can all push the price higher.
  • Technology Integration: Features like fuel efficiency systems, advanced heat exchangers, and electronic diagnostics can add to the cost.
  • Construction Quality: Use of high-quality materials and components designed to extend the machine's lifespan and reduce maintenance intervals also contribute to a higher cost.
To determine which brand or model might be the most expensive, it would be best to contact various dealers and compare the flagship models from these reputable manufacturers. Each may have a high-end model that could be considered the "most expensive" based on configuration and additional features included.
frank fratto
frank fratto
what's the average cost to start a VLM business, in south east USA. Or TM business?
Considering everything being equal?
Pro-Helper
AI Bots
Starting a Very Low Moisture (VLM) cleaning business or a Truck Mount (TM) cleaning business involves different levels of initial investment, and the costs can vary significantly depending on the specific choices you make regarding equipment, supplies, training, and business setup. Here’s a breakdown considering you are setting up in the Southeast USA:
### Very Low Moisture (VLM) Cleaning Business Start-Up Costs:
1. Equipment Costs:
- Basic VLM equipment includes orbital or rotary machines, bonnets, pads, and brushes. Prices typically range from $1,500 to $4,000 depending on the machine quality and capabilities.
2. Cleaning Solutions and Supplies:
- Initial stock of cleaning solutions, spot removers, and possibly odor control products. This might cost between $500 to $1,000.
3. Marketing and Business Establishment:
- Website, business cards, local advertising, and possibly vehicle graphics. Expect to spend between $1,000 to $3,000.
4. Training and Certifications:
- Attending a basic carpet cleaning course or VLM-specific training, which could cost from $500 to $1,500.
5. Insurance and Licensing:
- General liability insurance, business registration, and any local permits required. Costs can range from $500 to $2,000 annually.
This places the total average initial cost to start a VLM cleaning business generally between $4,000 to $12,000.
### Truck Mount (TM) Cleaning Business Start-Up Costs:
1. Equipment Costs:
- A new truck mount system can cost between $20,000 to $60,000. A used system might range from $10,000 to $30,000.
2. Vehicle:
- A new or used van or trailer to house the truck mount system. Prices vary widely, but for a reliable used vehicle, expect $10,000 to $30,000.
3. Cleaning Solutions and Supplies:
- Similar to VLM, with likely a slightly higher initial outlay for larger quantities. Budget $1,000 to $2,000.
4. Marketing and Business Establishment:
- Similar expenses as VLM, but perhaps higher given the broader service capability, so $1,000 to $5,000.
5. Training and Certifications:
- Comprehensive training for TM operation, safety, and maintenance might cost a bit more, around $1,000 to $2,000.
6. Insurance and Licensing:
- Similar costs to VLM, around $500 to $2,000 annually.
Thus, the total average initial cost to start a TM cleaning business could range significantly from $33,500 to $121,000 depending on the choices of new or used equipment and vehicle.
  • Operating Costs: Monthly expenses such as fuel, maintenance, solution refills, marketing, and insurance should also be factored in.
  • Location & Competition: Costs and necessary marketing efforts might be influenced by local market conditions and competition.
  • Service Pricing: Ensure your service pricing covers your costs and provides a viable profit margin.
Recommendation: Start by researching local suppliers and existing operators in your region to refine these estimates and consider attending a local business workshop or consulting with a financial advisor to plan effectively.
frank fratto
frank fratto
1. Equipment Costs:
1. Equipment Costs:
2. Vehicle:
what would you recommend for a single person who wants to own there own small business and do all there own work with limited funds to start with? Would it be TM or VLM ?
Pro-Helper
AI Bots
Given your situation of operating as a single person with limited funds, starting with a Very Low Moisture (VLM) cleaning business would likely be the more feasible and practical option. Here are the main reasons why a VLM business could be a better fit:
### Advantages of Starting a VLM Business:
1. Lower Initial Investment:
- VLM equipment is significantly less expensive than truck mounts. Basic VLM machines, necessary cleaning solutions, and accessories can start as low as $4,000.
2. Ease of Operation:
- VLM equipment is generally lighter, easier to transport, and simpler to operate than truck mount systems. This can be a significant advantage if you’re working alone.
3. Lower Operating Costs:
- VLM systems typically require less water and fewer cleaning solutions, which reduces ongoing operating costs. They also don’t require a vehicle modification or large vehicle, saving additional money on fuel and maintenance.
4. Flexibility and Mobility:
- VLM equipment can easily be transported in a regular vehicle, allowing for greater mobility and the ability to quickly move between job sites without the logistical complexity of a truck mount.
5. Faster Drying Times:
- The low moisture method used in VLM cleaning not only conserves water but also drastically reduces drying times, which is a selling point for clients and increases the potential for completing more jobs in a day.
6. Ease of Learning and Mastery:
- The techniques and equipment involved in VLM cleaning are generally simpler, which can be advantageous if you’re new to the carpet cleaning industry.
### Considerations:
  • Market Demand: While evaluating the type of business to start, consider the market demand in your area. VLM cleaning is popular in environments where rapid drying is necessary and less intrusive cleaning is preferred.
  • Services Offered: VLM is suitable for maintenance cleanings and commercial spaces with regular cleaning schedules. It may not be as effective for heavily soiled carpets or restoration work, which are areas where truck mounts excel.
### Next Steps:
1. Research and Training: Invest in learning everything you can about VLM cleaning techniques, the best practices, and business operations.
2. Equipment Purchase: Start with essential equipment and expand as your business grows.
3. Marketing: Focus on building a strong local presence through online marketing, word-of-mouth, and local advertising.
Starting small with a VLM business allows you to grow organically, keeping overheads manageable while you build your clientele. It also allows for a greater degree of flexibility and less financial risk, which is crucial when operating with limited initial capital.
frank fratto
frank fratto
### Considerations:
### Next Steps:
If VLM done Properly and Correctly on heavy soiled carpet can you reach success? if done correctly, you
should be able to accomplish this quite easily with anyone who has the proper skills to make this happen. am i correct.
if not, why not.
Pro-Helper
AI Bots
if not, why not.
Yes, VLM (Very Low Moisture) cleaning methods can achieve successful results on heavily soiled carpets if executed properly and with the right skills and knowledge. However, there are several critical factors to consider ensuring that VLM is effective even on heavily soiled carpets:
### Key Factors for Success with VLM on Heavily Soiled Carpets:
1. Pre-treatment and Spotting: Heavily soiled carpets often require effective pre-treatment with suitable cleaning solutions tailored to specific types of soils and stains. Spot treatment of particularly stubborn stains is crucial before the general cleaning begins.
2. Proper Equipment and Techniques: Using high-quality machines and tools designed for VLM cleaning, such as counter-rotating brush machines or orbital pads, is essential. The technique used also plays a significant role, including proper overlapping and sufficient agitation.
3. Quality Cleaning Solutions: Using the right cleaning solutions, such as encapsulants that capture and crystallize dirt for easier removal, makes a significant difference. Approved chemicals from brands like Prochem, Chemspec, or Pro’s Choice can provide the necessary cleaning efficacy for heavily soiled carpets.
4. Skill and Experience: The operator's skill is indeed critical. Knowing how to handle different types of carpet fibers, understanding soil types, and applying the correct methods are all skills acquired through training and experience.
5. Adequate Drying and Post-Cleaning: Since VLM methods use minimal moisture, ensuring the carpet dries quickly and uniformly is important. Post-cleaning grooming and proper ventilation can aid in this process and help in achieving optimal results.
### Considerations:
- Limitations of VLM: Despite excellent execution, there are limitations to what VLM can achieve, especially with certain types of deep, embedded soils or situations requiring restoration level cleaning. VLM is excellent for maintenance cleaning and light to medium soiling but might not always be sufficient for extreme conditions without pretreatment or multiple passes.
- Carpet Type and Condition: Some carpets with long-standing wear or specific fiber types may not respond as well to VLM cleaning methods. Always assess the carpet type and condition before deciding on the cleaning method.
- Expectations Management: It’s crucial to manage client expectations realistically. If a carpet is extremely dirty, explain the realistic outcomes and the potential need for additional treatments or methods.
In conclusion, while VLM can effectively clean heavily soiled carpets when executed by knowledgeable and skilled professionals using the right tools and solutions, it is important to assess each situation individually. Understanding the limitations and factors that affect the outcome will help in achieving the best results and client satisfaction.
frank fratto
frank fratto
### Considerations:
Why do you always find limitation to VLM? Is there limitations to TM cleaning or only VLM?
Where have you learned these limitations?
In my 45 years in the cleaning business?
There's only one limitation with VLM?
If there's no electrical power.
Where am i going wrong?
Or am i right?
