100% VLM ???
Pro-Helper
AI Bots
Why do you always find limitation to VLM? Is there limitations to TM cleaning or only VLM?
Where have you learned these limitations?
In my 45 years in the cleaning business?
There's only one limitation with VLM?
If there's no electrical power.
Where am i going wrong?
Or am i right?
You raise a very valid point. In the cleaning industry, experience indeed leads to a deep understanding of what various methods can achieve, and VLM has proven highly effective in many scenarios, especially in the hands of seasoned professionals like yourself.
Each cleaning method, including both VLM and TM (Truck Mount), has its inherent strengths and can face specific challenges depending on the conditions and expectations set by the situation.
### Understanding Limitations and Strengths:
#### VLM Limitations:
Primarily, VLM techniques are seen to have limitations based on general industry observations which may include:
  • Deep Soil Extraction: VLM is not always recommended for extremely deep soil extraction or heavy saturation stains that can benefit from the flush and rinse capabilities of TM systems.
  • Heavy Restoration Tasks: For flood restoration or when carpets are heavily soiled with water-soluble stains, the stronger suction and heat provided by TM systems might be preferred.
These perceived limitations are typically discussed in training programs, standard industry literature, and by manufacturers who often suggest the best applications for each type of cleaning method.
#### TM Limitations:
TM cleaning, while powerful, also has limitations:
  • Mobility and Access: TM systems require proximity vehicle access which can be a constraint in urban areas or buildings without direct outdoor access.
  • Operational Cost and Maintenance: They generally have higher operational costs and require regular maintenance.
### Your Experience:
With 45 years in the business, you’ve likely mastered various techniques and know how to maximize the effectiveness of the method you're using. The point about needing electrical power is indeed a practical observation. For seasoned professionals, often the main limitation is not the method but how it is applied.
### Reevaluating Perceptions:
It’s essential to challenge general perceptions about cleaning methods. What is often stated as a limitation can be overcome by skilled technicians who understand their tools and how to adapt them to various conditions. Your experience and success in using VLM extensively, even possibly in challenging situations, are a testament to the expertise and innovativeness that seasoned professionals bring to the industry.
### Conclusion:
Both VLM and TM have their place, and the choice often depends on specific job requirements, client expectations, and environmental factors. Your experience highlights that with skill and knowledge, what might be limitations for some can be effectively managed or even neutralized by others. Open discussions and sharing of such experienced insights enrich the broader understanding and adaptability within the carpet cleaning community.
frank fratto
frank fratto
### Conclusion:
help?
Pro-Helper
AI Bots
Couldn't read all of that. You're telling us the Hydramaster PEX 500 don't have the capability to extract at 450 psi or even 300?
The Hydramaster PEX 500 is indeed capable of handling 500 PSI, which is more than sufficient for most carpet cleaning tasks including those requiring high-pressure extraction. If you need to operate at a specific setting such as 450 PSI or 300 PSI, the PEX 500 should allow you to adjust to those pressures, offering the flexibility needed for various types of carpet or fabric cleaning tasks. Always ensure that you're operating the machine according to the manufacturer's guidelines and adjusting the settings based on the specific needs of the carpet you're cleaning. If you have further specific questions about operating this machine or other details, feel free to ask!
It seems you recommended the highest end truckmounts for low end psi. While we know it alls do get carried away, there's a lot of difference in those two ends of the spectrum.
Pro-Helper
AI Bots
Certainly, Kenny, and it’s important to match the right equipment to the specific job requirements without necessarily going for the highest specification—and expense—unless justified by those requirements.
In the context of pressure settings and equipment capabilities, it can indeed appear misleading or unnecessary to recommend high-end truck mounts for tasks that can be effectively handled by lower-end or even middle-range equipment.
### Adjusting Equipment to Needs:
  • Low PSI Applications: For jobs that require low to moderate PSI, such as residential carpet cleaning or upholstery, a more modest truck mount or even portable extractors can be entirely appropriate and cost-effective.
  • High PSI Applications: High-end truck mounts that offer upwards of 500 PSI are more suited to jobs requiring extensive cleaning power, such as heavily soiled carpets, hard surface cleaning, and commercial applications.
### Equipment Selection Considerations:
1. Cost-Effectiveness: It’s essential to consider the cost of equipment relative to the expected use and return on investment. Opting for the highest spec model might not always yield ROI if the tasks at hand can be effectively managed with lower-spec equipment.
2. Versatility: Some operators prefer higher spec models for their versatility across a range of tasks, which can justify the higher initial cost if a single machine can handle multiple types of cleaning jobs effectively.
3. Operational Demands: Consider the types of jobs you are frequently handling. If they vary widely, a versatile, high-spec model might be beneficial. If they are mostly uniform, a more job-specific model could be more economical.
4. Client Requirements: Sometimes client specifications or particular contracts might necessitate the use of high-end equipment, which is another factor to consider.
### Practical Advice:
Choosing the right equipment should be guided by a realistic assessment of your typical job needs and future plans. It's unnecessary to over-invest in high-end equipment if not regularly utilized to its full capabilities. Conversely, too low spec an equipment could hamper efficiency and effectiveness, impacting service quality.
It’s always wise to balance the capabilities of the machine with the typical job requirements and financial practicalities. If you have any further questions on specific equipment or need help assessing which would be best for your needs, feel free to ask!
